  4. Took head off after breakdown
33 Posts 7 Posters 10.6k Views
  • ZrakoZ Zrako
    Well , brand new iridium br9eix after like 30 minutes idling. First 5 minutes was bleeding oil pump. Doesnt smoke too much . 🤕
    @Zrako A bit rich, but you won't really tell unless you do a plug chop.
    • ZrakoZ
      ZrakoZ
      Zrako
      @Calum what exactly does that plug chop is ? Never heard that before
      1979 Jawa Mustang 50
      2003 Gilera DNA 125 R.I.P
      2015 Keeway TX 125 SM
      2006 Yamaha DT 125 X
      • ZrakoZ Zrako
        @Zrako http://kawtriple.com/mraxl/carb/plugchop.htm
        https://www.google.co.uk/search?q=plug+chop&ie=utf-8&oe=utf-8&client=firefox-b-ab&gfe_rd=cr&ei=1eVrWaveI6fA8gf04rnACA
        Google my friend.
        ZrakoZ 1 Reply Last reply
          Google my friend.
          ZrakoZ
          ZrakoZ
          Zrako
          @Calum whoa . I need to get some standard plugs then . Thanks for help again
          • ZrakoZ Zrako
            @Zrako my bikes clog up on idle give it a nice few revs to clear it out
            • MightymanM
              MightymanM
              Wow I have never actually read this up before. Always assumed a "plug chop" was running the bike for couple minutes, then visually inspecting the plug. Seems like a lot of effort / plug money to get it running perfect, but obviously worth it. Nothing better than a 2 stroke motor purring over perfectly. 👍
                @Mightyman and you know what they say about assumptions.
                Oh my bad, seriously I thought it was common knowledge.
                • ZrakoZ
                  ZrakoZ
                  Zrako
                  Completed the bike again 100% , 10 minutes warm up , took it on the street . Hardly powerband , valve moving properly but struggled . Tried to go between the gears hardly 3rd only sometimes . Impossible to shift , only with heel 😑. Took it apart again and tried to figure out whats going on. I think this is the problem.
                  https://youtu.be/xqXsdSxaTwQ
                  I think the sping is slacked. Found picture in the haynes
                  Did anyone experienced something like this?
                  • A
                    A
                    andrewj1680
                    My spring doesnt come up through the holes like yours does, the legs sit underneath the same as it does in the Haynes manual image
                    • ZrakoZ
                      ZrakoZ
                      Zrako
                      Cant find the spring for sale . Just the new shaft 😓
                      • A
                        A
                        andrewj1680
                        I dont think you need a new spring you need to push the feet of the spring back through, the spring is pretty slack on all ive seen but not had any gear selection problems
                        • A
                          A
                          andrewj1680
                          0_1500416320929_20170718_231423.jpg 0_1500416356105_20170718_231411.jpg 0_1500416380228_20170718_231253.jpg 0_1500416405701_20170718_231238.jpg
                          • A
                            A
                            andrewj1680
                            Worse case its only £41+vat complete new
