  4. 2002 dt125r rev limit??
39 Posts 8 Posters 9.7k Views 1 Watching
  • M Mitch_350z
    @calum it seems to ride better when pinned but still only does 65 max and doesn't pull too well in 6th?? Struggles a little to rev up to but don't know If this is because of the pinning??
    @mitch_350z It shouldn't pull well at the lower RPMs, but past 6 it should pull hard to 12. If it doesn't then it's not the powervalve causing the problem.
    M 1 Reply Last reply
      M Offline
      M Offline
      Mitch_350z
      @calum ok thanks mate I'll have to do a bit more digging, just out of curiosity my other dtr I had was also a 2002 but had a 3 wire servo rather than the 5 wire this one has?? What difference does this make??
      Cheers Mitch
      • DartyD Offline
        DartyD Offline
        Everybody has to remember that 99' onwards 3RM DT's are CDI restricted to 8,500 RPM...
        So, don't expect anything like a 3 wire servo Pre 96' model.
        CalumC F 2 Replies Last reply
        • DartyD Darty
          @darty The DTRE's are not restricted to 8500. The DTR's may be.
          • DartyD Darty
            F Offline
            F Offline
            @darty definitely not, my DTX goes way past that.
            • F finnerz89
              @finnerz89 Well, I wouldn't say WAY past. I think it's 10k. Because the Powervalve closes then and then it really struggles. But it's as simple as earthing the black and green wire then you get full power.
              F 1 Reply Last reply
                F Offline
                F Offline
                @calum I've had 12k a couple of times. Earthing that cable transformed it
                DartyD 1 Reply Last reply
                • F finnerz89
                  DartyD Offline
                  DartyD Offline
                  wrote on last edited by Darty
                  #28
                  @finnerz89 Yeah sick, the DTRs though - are different sadly.
                  DTRE/X use a non Restricted CDI.
                  2002''s are doomed to 8.5k.
                  N M 2 Replies Last reply
                  • DartyD Darty
                    @darty My '03 was de-restricted and went up to 11K+ NP's. πŸ™‚
                    • N NINJA
                      DartyD Offline
                      DartyD Offline
                      @cyber-ninja Tell you what, it's said that there were some 3RM CDI's that were Unrestricted from factory for last model 2003'
                      I can't remember the CDI code, if you had one, that was pretty rare!
                      N Sgt Robuck 5S 2 Replies Last reply
                      • DartyD Darty
                        @darty I can't answer that for you as I sold the bike, but if it was an un-restricted CDI then yes I was very lucky indeed!! πŸ™‚
                        • DartyD Darty
                          M Offline
                          M Offline
                          Mitch_350z
                          @darty could this be as simple as swapping the cdi for an unrestricted one or is this not possible??
                            My brother had a 2001 DTR and it was slow as fook.
                            Although once derestricted it went like stink.
                            Pretty sure he swapped out the CDI though.
                              @calum do most still have the reed valve behind the clock or is that only for speed not revs?
                              N 1 Reply Last reply
                                #35
                                @declan I believe that it's a sensor which forms part of the de-restriction system. It monitor's RPM's and when a set limit is reached it retards the CDI/engine from going any higher. Hence if you unplug the sensor then in theory your engine is capable of reaching it's highest maximum RPM.
                                declanD M 2 Replies Last reply
                                • N NINJA
                                  @cyber-ninja I have no reed switch I have no grey box in front of the oil tank but my bike is a pre 99 I can't find any restrictions 😐
                                  • N NINJA
                                    M Offline
                                    M Offline
                                    Mitch_350z
                                    @cyber-ninja I have moved the reed switch behind the speedo but not unplugged anything??
                                    • DartyD Darty
                                      Sgt Robuck 5S Offline
                                      Sgt Robuck 5
                                      @darty They are rare? I currently have a dtr 125 2002 (Registered as a 2003)
                                      • Sgt Robuck 5S Sgt Robuck 5
                                        @sgt-robuck-5 you don’t see too many of that era of dt I don’t know if there rare I’m just speaking from experience in looking to buy although you will find them usually it’s an older
                                        Model that you will come across
