  4. TDR issue
TDR issue
97 Posts 12 Posters 35.0k Views 1 Watching
  • NottsbikerN
    NottsbikerN
    wrote on last edited by Nottsbiker
    #58
    Lebancoin
    You will struggle to find anyone willing to post to the uk and the shipping rates are crazy from here.
    Loads of lovely WR200's out here too 😉
    J'ai trouvé une annonce qui devrait vous intéresser sur leboncoin
    http://www.leboncoin.fr/vi/1304264710.htm
    ricky0115R 1 Reply Last reply
    • NottsbikerN
      NottsbikerN
      An example of a colour scheme I really like the look of;
      http://www.leboncoin.fr/vi/1178632750.htm
      T 1 Reply Last reply
      • NottsbikerN Nottsbiker
        T
        T
        TDRnoob
        @nottsbiker That is sexy
        • T
          T
          TDRnoob
          Another update with the brand new issue
          Cold bike. I couldn't start start it. It didn't accept the throttle. Started with the choke only. When warmed up everything worked fine with the choke off.
          Spent about 10 minutes on adjusting the carburetor air screw (to get the highest rev on idle)
          Noticed that the bike is heating up a bit to fast. (Heat arrow pointed at 3/4)
          Decided to go for a ride
          In the beginning accelerated well, after 2-3 minutes started to feel like something is dragging behind.
          Engine was running very slowly and it didn't accept the throttle.
          I stopped and noticed that in neutral gear is hard to push bike forward of backwards. Looks like the engine is tight?
          When it gets colder then gets back to normal.
          Video
          https://www.youtube.com/watch?v=KV5ynUc5-xw&feature=youtu.be
          Any thoughts?
          Regards
          DartyD T 2 Replies Last reply
          • T TDRnoob
            Video
            Any thoughts?
            Regards
            wrote on last edited by Darty
            #62
            @tdrnoob DEAR GOD 😦 Poor engine.
            IT'S LEAN FOR SURE,
            I'm pretty sure that is an outrageously lean fuel condition.
            That is bad.
            Very bad.
            Get to Jetting that before riding it anymore,
              IT'S LEAN FOR SURE,
              That is bad.
              Very bad.
              T
              T
              TDRnoob
              wrote on last edited by TDRnoob
              #63
              @darty said in TDR issue:
              I mixed petrol as per instructions. Used about 35 ml of 2 stroke oil with 1 litre petrol.
              No idea what to do with jetting.
              I didn't expect that after full engine rebuild 😕
              • NottsbikerN
                NottsbikerN
                Did you check the carb was still on factory settings and ensure that it was squeaky clean?
                  T
                  T
                  TDRnoob
                  @nottsbiker I didnt change anything in carb. Dissembled and cleaned with the carb cleaner. Then put it back together as it was before
                  • NottsbikerN
                    NottsbikerN
                    Worth checking that the inlet rubber is not perished then (between carb and engine). Mine is shot to pieces and I've yet to see a new one for sale 😞
                    O T 2 Replies Last reply
                      @nottsbiker said in TDR issue:
                      Cmsl have them, 40 € exc postage
                      • NottsbikerN
                        NottsbikerN
                        Belgarda version?
                        Watching loads of items I need at moment but would definitely buy one later at that price
                          T
                          T
                          TDRnoob
                          @nottsbiker I will check that.
                          Thank you
                          • T TDRnoob
                            Thank you
                            @tdrnoob That should pick up a lot quicker than that.
                            This needs investigating for sure.
                            If it's running lean, then the plug will be plastered white.
                            It's hard to tell from that video, but that's where I'd start.
                            • Irongamer727I
                              Any progress regarding the weird noise coming from the engine?
                              • NottsbikerN
                                NottsbikerN
                                Be interested to hear how you are getting on as well
                                  T
                                  T
                                  TDRnoob
                                  @irongamer727 Do you mean the whistle?
                                  Looks like it is the problem with the starter, but I think it does not affect the main issue
                                  • T
                                    T
                                    TDRnoob
                                    Spark plug news
                                    According manual it looks like it is carbon fouling colour
                                    Causes
                                    rich fuel/air mixture (maybe air leek)
                                    faulty choke (Not sure how to check as it looks all right)
                                    blocked air filter (probably not)
                                    Pictures
                                    0_1505935801183_gide.jpg 0_1505935812808_20170920_170502.jpg 0_1505935827163_20170920_170536.jpg 0_1505935857720_20170920_172406.jpg 0_1505935864956_20170920_184809.jpg 0_1505935889032_20170920_180105.jpg
                                    • T TDRnoob
                                      Spark plug news
                                      Causes
                                      Pictures
                                      T
                                      T
                                      TDRnoob
                                      #75
                                      @tdrnoob Found a small crack on that rubber, but it looked not too deep.
                                      I have put some glue.
                                      Last picture is to compare my one on right and the other one left from DT 125 (had a spare one). It looks like someday my one was modified.
                                      • T
                                        T
                                        TDRnoob
                                        0_1505936194058_20170920_173835.jpg 0_1505936188379_20170920_173831.jpg 0_1505936199009_20170920_173844.jpg
                                        Some pictures of my carb with a float.
                                        Any advice about the level.
                                          Lebancoin
                                          ricky0115R
                                          ricky0115R
                                          ricky0115
                                          Lebancoin
                                          Oh please bring me some wr200 forks back 😂
