tuningdtryamaha2003wr200
254 Posts 25 Posters 240.5k Views 6 Watching
  • Louis-DT-WRL Louis-DT-WR
    Just made the school boy error of spraying all over the clutch with brake cleaner to get all the old oil out of the transmission but forgetting that there needs to be oil on the clutch plates so they can fully disengage.
    Hopefully when I start it up in a weeks time with new fuel and rad the oil will get in the plates and free it all up 🙂
    @Louis-James soak them in oil over night, best method for it!
    • MightymanM Mightyman
      Louis-DT-WRL
      Louis-DT-WRL
      @Mightyman I know haha I just forgot as it's been a while 😂, I didn't replace the plates, I replaced one spring at a time and blasted loads brake cleaner I. Im pretty sure I did this once years ago but it soon sorted. I probably will change the plates in the near future.
      • Louis-DT-WRL
        Louis-DT-WRL
        rads all welded up ready, need to trim the top bracket for frame clearance. Bolts up nicely, pressure tested.
        Also taken off every sticker on the bike that looks tacky and just kept YAMAHA logo ones.
        Also test fitted my headlight guard, needs powdercoating white though. Gives it a trail look 🙂
        • Louis-DT-WRL
          Louis-DT-WRL
          #135
          Painted the core for a more stealthy look, also hides all the dust that gets caught in the fins.
          MightymanM 1 Reply Last reply
            @Louis-James isn't that the one bit you don't want to paint?! 😂
              Louis-DT-WRL
              Louis-DT-WRL
              @Mightyman it won't effect the cooling, it's so thin. I've had my intercooler powdercoated 😂
              • Louis-DT-WRL
                Louis-DT-WRL
                #138
                It's on, really good fit!
                Hoses line up, clearance everywhere is perfect.
                Cap is easy to remove. Can't wait to run it.
                MightymanM NINJAN 2 Replies Last reply
                  @Louis-James looking very nice!
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @Mightyman thanks 🙂 just got to take off the fuel tank for a new tap and empty old fuel. At the same time I will bleed the cooling system.
                      Sweeeet. Go on, make me one!
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Darty if you buy the core on eBay (£25) and take it to a welder with your old one and the subframe, they could make it easy
                        • MiniaM
                          MiniaM
                          Minia
                          Good work mate, such a sexy bike that is.
                          • MiniaM Minia
                            Louis-DT-WRL
                            Louis-DT-WRL
                            @Minia cheers mate 🙂
                              @Louis-James Nice neat job their mate. 👍
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @CYBER-NINJA cheers 🙂
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  CalumC MiniaM 2 Replies Last reply
                                    [[topic:post-is-deleted]]
                                    @Louis-James Don't worry about what other people think!
                                    It's your bike no one elses!
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      #149
                                      @Calum thanks I don't 🙂 but I know some people will. Not necessarily on here.
                                      Also they don't even make extenders anymore, old stock from the late 80s haha
                                        @Louis-James I reckon that's a cool idea, it's what the DT is about
                                          MiniaM
                                          MiniaM
                                          Minia
                                          @Louis-James What a fantastic looking bike. My uncle had a XT650 from the 80s, was a holiday bike so watching my uncle and cousin trying to kick start it was amusing, they literally would have a run-up and then jump on it. Anyway, looks great! I'll keep an eye on the project!
