tuningdtryamaha2003wr200
254 Posts 25 Posters 243.6k Views 6 Watching
    Wow, dare I ask how much!!!
    Louis-DT-WRL
    Louis-DT-WRL
    @Calum Claimed the vat back through families company but £318 excluding vat.
    One-day there will be none left.
    Had a end of tax year bounty from HM 🙂
    • Louis-DT-WRL Louis-DT-WR
      @Louis-James That's actually really cheap.
      Yes you are right Louis, however there will always be better engines to transplant should that be the case.
      Hell even electric engines are far superior to most petrol motors/.
        Louis-DT-WRL
        Louis-DT-WRL
        @Calum almost worth making a whole new engine haha, I like the idea of a yz250 evolution 88 motor, don't fancy chopping the frame though. Maybe I'll get the bike one-day
        • Louis-DT-WRL
          Louis-DT-WRL
          #130
          Got some work done.
          Replaced the clutch springs for the uprated wr200 version (15% stiffer than stock WR) they are actually longer, but that's one way to make the sprung force stronger.
          Oil and Coolant change, replaced the 2t to manifold hose for another clear one as it has gotten cloudy.
          Polished the exhaust and detail cleaned the underside of the engine in every nook and cranny that was left from rain riding haha.
          Straightend up the rear silencer as it was aiming to my number plate and getting lots of gank on it.
          And resealed the slip on part on the downpipe (I hate slip on!)
          Got a new fuel tap to fit when the radiators welded up, I'll do it together.
          A few new visual mods I'm toying with are to come (make it more original trail look)
          • Louis-DT-WRL
            Louis-DT-WRL
            Just made the school boy error of spraying all over the clutch with brake cleaner to get all the old oil out of the transmission but forgetting that there needs to be oil on the clutch plates so they can fully disengage.
            Hopefully when I start it up in a weeks time with new fuel and rad the oil will get in the plates and free it all up 🙂
            MightymanM 1 Reply Last reply
              @Louis-James soak them in oil over night, best method for it!
              • MightymanM Mightyman
                Louis-DT-WRL
                Louis-DT-WRL
                @Mightyman I know haha I just forgot as it's been a while 😂, I didn't replace the plates, I replaced one spring at a time and blasted loads brake cleaner I. Im pretty sure I did this once years ago but it soon sorted. I probably will change the plates in the near future.
                • Louis-DT-WRL
                  Louis-DT-WRL
                  rads all welded up ready, need to trim the top bracket for frame clearance. Bolts up nicely, pressure tested.
                  Also taken off every sticker on the bike that looks tacky and just kept YAMAHA logo ones.
                  Also test fitted my headlight guard, needs powdercoating white though. Gives it a trail look 🙂
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    #135
                    Painted the core for a more stealthy look, also hides all the dust that gets caught in the fins.
                      @Louis-James isn't that the one bit you don't want to paint?! 😂
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Mightyman it won't effect the cooling, it's so thin. I've had my intercooler powdercoated 😂
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          #138
                          It's on, really good fit!
                          Hoses line up, clearance everywhere is perfect.
                          Cap is easy to remove. Can't wait to run it.
                          MightymanM NINJAN 2 Replies Last reply
                            @Louis-James looking very nice!
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @Mightyman thanks 🙂 just got to take off the fuel tank for a new tap and empty old fuel. At the same time I will bleed the cooling system.
                                Sweeeet. Go on, make me one!
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @Darty if you buy the core on eBay (£25) and take it to a welder with your old one and the subframe, they could make it easy
                                  • MiniaM
                                    MiniaM
                                    Minia
                                    Good work mate, such a sexy bike that is.
                                    • MiniaM Minia
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @Minia cheers mate 🙂
                                        @Louis-James Nice neat job their mate. 👍
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          @CYBER-NINJA cheers 🙂
