  4. TDR issue
TDR issue
97 Posts 12 Posters 31.2k Views 1 Watching
  • NottsbikerN Offline
    NottsbikerN Offline
    Ah sorry i misunderstood
    They come fitted to the WR200 as standard or you can buy them on ebay with this item number
    192262337902
    T 1 Reply Last reply
    • NottsbikerN Nottsbiker
      192262337902
      T Offline
      T Offline
      TDRnoob
      @nottsbiker Thanks
        NottsbikerN Offline
        No problem dude
          Mybelgarda oil pump failed and couldn't be adjusted. It just rinsed oil.
          I went premix in the end.
          T Offline
          T Offline
          TDRnoob
          @calum Hi. Did you change jetting after when you went for premix? If changed then could you remember what sizes for pilot jet and main jet. Thank you
          • T TDRnoob
            @tdrnoob I ran a completely different carburetor, so all my jet sizes would have been changed.
            Plus I ran far from standard settings. Jetting must done to suit the machine you are riding, no two machines are the same so jetting is best done to accommodate this.
              T Offline
              T Offline
              TDRnoob
              @calum I have found the details of my carb it is
              PHBH28 Dellorto carb
              main: 142
              choke: 60
              atomiser: 266d
              needle: x18
              pilot :45
              I have removed the oil pump and installed the plate cover for hole. Tomorrow engine is coming back after bottom rebuild. Just thinking should I change jetting. Any advice
              • T TDRnoob
                main: 142
                choke: 60
                atomiser: 266d
                needle: x18
                pilot :45
                @tdrnoob I'm not familiar with that carburetor myself, as said, jet accordingly.
                If it's detonating, if it's spluttering, then you may need to jet to suit.
                But at a guess I wouldn't have thought you'd need to rejet.
                  T Offline
                  T Offline
                  TDRnoob
                  @calum Thank you
                    NottsbikerN Offline
                    You should be able to get any spares you need from Allens Performance who stock parts for all makes of carb
                      T Offline
                      T Offline
                      TDRnoob
                      @nottsbiker Hi. You wrote earlier to increase the jetting by 5%. It has pilot jet and main jet so do you mean those two to change to higher ones by 5%?
                      I will test the bike with the original ones first
                        NottsbikerN Offline
                        Ps I've picked up a complete pdf of the 3SH parts list with full pictures and Yamaha part numbers from the German TDR forum.
                        I'm currently in France on holiday but can email it to you when I'm near some wifi if it's any use to you?
                        • T TDRnoob
                          NottsbikerN Offline
                          NottsbikerN Offline
                          @tdrnoob said in TDR issue:
                          I'm not an expert on jetting just relaying what I'd read years back. If in doubt get it set up by a tuner
                            T Offline
                            T Offline
                            TDRnoob
                            @nottsbiker Thats great! I really need it.
                            Could you please email it to me d.matuiza@gmail.com
                            Many thanks
                              NottsbikerN Offline
                              Sent over!
                              • MightymanM Offline
                                MightymanM Offline
                                @Nottsbiker is there many pages? It would be great if we can get them uploaded into a thread of their own.
                                  NottsbikerN Offline
                                  Iirc about 70 ish
                                  • T Offline
                                    T Offline
                                    TDRnoob
                                    Quick update
                                    So my TDR belgarda had a full engine rebuild by Roadrunners motorcycles.
                                    Also I have started premix. I used about 35 ml of 2 stroke oil to mix with the petrol.
                                    There is video
                                    https://www.youtube.com/watch?v=gjEHSmpNIgg
                                    What do you think guys?
                                    Just wondering if it everything ok.
                                      I used 200ml oil to a full tanks. Approx 10 litres.
                                      Lovely little whistle to that engine too. Sounds great.
                                        MightymanM Offline
                                        Never heard a sound like that coming from one of these 😂
                                        • O Offline
                                          O Offline
                                          Sounds a bit chirpy? Can't think what would cause that, unless its just the recording
