  4. TDR issue
TDR issue
97 Posts 12 Posters 35.0k Views 1 Watching
    Mybelgarda oil pump failed and couldn't be adjusted. It just rinsed oil.
    I went premix in the end.
    T
    T
    TDRnoob
    @calum Hi. Did you change jetting after when you went for premix? If changed then could you remember what sizes for pilot jet and main jet. Thank you
    • T TDRnoob
      @tdrnoob I ran a completely different carburetor, so all my jet sizes would have been changed.
      Plus I ran far from standard settings. Jetting must done to suit the machine you are riding, no two machines are the same so jetting is best done to accommodate this.
      T 1 Reply Last reply
        T
        T
        TDRnoob
        @calum I have found the details of my carb it is
        PHBH28 Dellorto carb
        main: 142
        choke: 60
        atomiser: 266d
        needle: x18
        pilot :45
        I have removed the oil pump and installed the plate cover for hole. Tomorrow engine is coming back after bottom rebuild. Just thinking should I change jetting. Any advice
        • T TDRnoob
          main: 142
          choke: 60
          atomiser: 266d
          needle: x18
          pilot :45
          @tdrnoob I'm not familiar with that carburetor myself, as said, jet accordingly.
          If it's detonating, if it's spluttering, then you may need to jet to suit.
          But at a guess I wouldn't have thought you'd need to rejet.
            T
            T
            TDRnoob
            @calum Thank you
            • NottsbikerN
              NottsbikerN
              You should be able to get any spares you need from Allens Performance who stock parts for all makes of carb
              • NottsbikerN Nottsbiker
                T
                T
                TDRnoob
                @nottsbiker Hi. You wrote earlier to increase the jetting by 5%. It has pilot jet and main jet so do you mean those two to change to higher ones by 5%?
                I will test the bike with the original ones first
                • NottsbikerN
                  NottsbikerN
                  Ps I've picked up a complete pdf of the 3SH parts list with full pictures and Yamaha part numbers from the German TDR forum.
                  I'm currently in France on holiday but can email it to you when I'm near some wifi if it's any use to you?
                  • T TDRnoob
                    NottsbikerN
                    NottsbikerN
                    @tdrnoob said in TDR issue:
                    I'm not an expert on jetting just relaying what I'd read years back. If in doubt get it set up by a tuner
                      T
                      T
                      TDRnoob
                      @nottsbiker Thats great! I really need it.
                      Could you please email it to me d.matuiza@gmail.com
                      Many thanks
                      • NottsbikerN
                        NottsbikerN
                        Sent over!
                        • MightymanM
                          @Nottsbiker is there many pages? It would be great if we can get them uploaded into a thread of their own.
                          • NottsbikerN
                            NottsbikerN
                            Iirc about 70 ish
                            • T
                              T
                              TDRnoob
                              Quick update
                              So my TDR belgarda had a full engine rebuild by Roadrunners motorcycles.
                              Also I have started premix. I used about 35 ml of 2 stroke oil to mix with the petrol.
                              There is video
                              https://www.youtube.com/watch?v=gjEHSmpNIgg
                              What do you think guys?
                              Just wondering if it everything ok.
                                I used 200ml oil to a full tanks. Approx 10 litres.
                                Lovely little whistle to that engine too. Sounds great.
                                • MightymanM
                                  Never heard a sound like that coming from one of these 😂
                                    Sounds a bit chirpy? Can't think what would cause that, unless its just the recording
                                    • ZrakoZ
                                      ZrakoZ
                                      Zrako
                                      Oh thats same thing as I had on my dt. Thats the starter clutch not releasing after engine start.
                                      1979 Jawa Mustang 50
                                      2003 Gilera DNA 125 R.I.P
                                      2015 Keeway TX 125 SM
                                      2006 Yamaha DT 125 X
                                      • NottsbikerN
                                        NottsbikerN
                                        Sounds like the engine is very tight to me from the rebuild. Hard to tell from a YouTube video
                                        Looks like you are making good progress though mate 🙂
                                        • ZrakoZ
                                          ZrakoZ
                                          Zrako
                                          https://youtu.be/cleKkIbDTeI
                                          Check my vid , same sound
