  4. TDR issue
TDR issue
97 Posts 12 Posters 31.2k Views 1 Watching
    @tdrnoob I ran a completely different carburetor, so all my jet sizes would have been changed.
    Plus I ran far from standard settings. Jetting must done to suit the machine you are riding, no two machines are the same so jetting is best done to accommodate this.
    T Offline
    T Offline
    TDRnoob
    @calum I have found the details of my carb it is
    PHBH28 Dellorto carb
    main: 142
    choke: 60
    atomiser: 266d
    needle: x18
    pilot :45
    I have removed the oil pump and installed the plate cover for hole. Tomorrow engine is coming back after bottom rebuild. Just thinking should I change jetting. Any advice
    • T TDRnoob
      main: 142
      choke: 60
      atomiser: 266d
      needle: x18
      pilot :45
      @tdrnoob I'm not familiar with that carburetor myself, as said, jet accordingly.
      If it's detonating, if it's spluttering, then you may need to jet to suit.
      But at a guess I wouldn't have thought you'd need to rejet.
      T 1 Reply Last reply
        T Offline
        T Offline
        TDRnoob
        @calum Thank you
        • NottsbikerN Offline
          NottsbikerN Offline
          You should be able to get any spares you need from Allens Performance who stock parts for all makes of carb
          • NottsbikerN Nottsbiker
            T Offline
            T Offline
            TDRnoob
            @nottsbiker Hi. You wrote earlier to increase the jetting by 5%. It has pilot jet and main jet so do you mean those two to change to higher ones by 5%?
            I will test the bike with the original ones first
              NottsbikerN Offline
              Ps I've picked up a complete pdf of the 3SH parts list with full pictures and Yamaha part numbers from the German TDR forum.
              I'm currently in France on holiday but can email it to you when I'm near some wifi if it's any use to you?
              • T TDRnoob
                NottsbikerN Offline
                NottsbikerN Offline
                @tdrnoob said in TDR issue:
                I'm not an expert on jetting just relaying what I'd read years back. If in doubt get it set up by a tuner
                  T Offline
                  T Offline
                  TDRnoob
                  @nottsbiker Thats great! I really need it.
                  Could you please email it to me d.matuiza@gmail.com
                  Many thanks
                    NottsbikerN Offline
                    Sent over!
                    • MightymanM Offline
                      MightymanM Offline
                      @Nottsbiker is there many pages? It would be great if we can get them uploaded into a thread of their own.
                        NottsbikerN Offline
                        Iirc about 70 ish
                        • T Offline
                          T Offline
                          TDRnoob
                          Quick update
                          So my TDR belgarda had a full engine rebuild by Roadrunners motorcycles.
                          Also I have started premix. I used about 35 ml of 2 stroke oil to mix with the petrol.
                          There is video
                          https://www.youtube.com/watch?v=gjEHSmpNIgg
                          What do you think guys?
                          Just wondering if it everything ok.
                            I used 200ml oil to a full tanks. Approx 10 litres.
                            Lovely little whistle to that engine too. Sounds great.
                              MightymanM Offline
                              Never heard a sound like that coming from one of these 😂
                              • O Offline
                                O Offline
                                Sounds a bit chirpy? Can't think what would cause that, unless its just the recording
                                • ZrakoZ Offline
                                  ZrakoZ Offline
                                  Zrako
                                  Oh thats same thing as I had on my dt. Thats the starter clutch not releasing after engine start.
                                  1979 Jawa Mustang 50
                                  2003 Gilera DNA 125 R.I.P
                                  2015 Keeway TX 125 SM
                                  2006 Yamaha DT 125 X
                                    NottsbikerN Offline
                                    Sounds like the engine is very tight to me from the rebuild. Hard to tell from a YouTube video
                                    Looks like you are making good progress though mate 🙂
                                    • ZrakoZ Offline
                                      ZrakoZ Offline
                                      Zrako
                                      https://youtu.be/cleKkIbDTeI
                                      Check my vid , same sound
                                        NottsbikerN Offline
                                        Never been posh enough to have an electric start DT so wouldn't know 😉
                                        • O Offline
                                          O Offline
                                          Nice colour red though😋
