  4. PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,)
tuningdtryamaha2003wr200
254 Posts 25 Posters 239.7k Views 6 Watching
    @Louis-James beaut wish mine revved that High still restricted you see 😔
    Louis-DT-WRL
    Louis-DT-WRL
    Louis-DT-WR
    @declan thanks guys. Normally revs out higher and smoother but fuels a bit old,
    • NottsbikerN
      NottsbikerN
      Like the headlight guard! Looks very hardcore 🙂
      • NottsbikerN Nottsbiker
        Louis-DT-WRL
        Louis-DT-WRL
        Louis-DT-WR
        @nottsbiker cheers, going for the tenere look 😉
        • NottsbikerN
          NottsbikerN
          Yes I can tell, especially with the XT / 200R mudguard with additional spoiler.
          Cant see pics as they are blocked at work but from the video looks like you've done a very good job mate 🙂
            Louis-DT-WRL
            Louis-DT-WRL
            Louis-DT-WR
            @nottsbiker it's photobucket holding me to ransom that's blocking the pictures
            • NottsbikerN
              NottsbikerN
              Maybe but our servers block the avatars etc anyways so hard to say from here
                @Louis-James you made that headlight guard right?
                  Louis-DT-WRL
                  Louis-DT-WRL
                  Louis-DT-WR
                  wrote on last edited by Louis-DT-WR
                  #208
                  This post is deleted!
                    alt
                    You are going to need the embed link mate.
                    You need the URL of the image, not the web address it can be found at.
                    Easiest way, just use Imgur.
                    • Louis-DT-WRL Louis-DT-WR
                      [[topic:post-is-deleted]]
                      #210
                      @louis-james The polishing on your exhaust pipe is extremely disappointing bud.
                      I can't see your face in the reflection, please fix this ASAP - Thanks!!! 😉
                      LOLLLZZZZZZZZZZZZZZZZZZZ
                      • O
                        O
                        Good work, satisfying innit! How many hours have you put in?
                          alt
                          Louis-DT-WRL
                          Louis-DT-WRL
                          Louis-DT-WR
                          @calum thanks callum, I tried imgur but apparently it's not supporting 3rd party hosting for much longer or its a rumour,
                          Someone mentioned a cloud button, I don't know what that it,
                          I'll keep trying until it works
                          MightymanM CalumC 2 Replies Last reply
                            Louis-DT-WRL
                            Louis-DT-WRL
                            Louis-DT-WR
                            @cyber-ninja I know, but it's the plating from new! It's always been like that, especially on that part of the front pipe
                            • O oldman
                              Louis-DT-WRL
                              Louis-DT-WRL
                              Louis-DT-WR
                              @oldman said in PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,):
                              Thank you, about 7years haha, on and off.
                              • NottsbikerN
                                NottsbikerN
                                Interesting you went with the DEP pipe as I'd have thought the FMF one from the WR would have suited your cylinder better. Any particular reason for this choice?
                                  MightymanM
                                  MightymanM
                                  #216
                                  @louis-james this GIF should show you how to use the little cloud button I mentioned. It actually uses Imgur but simplifies the process for everyone here. I haven't heard of them cancelling 3rd party support but it would be very frustrating for us and many others if they do.
                                  Note that if you are on mobile, you may need to swipe left on the editing tools to see it!
                                    @louis-james Literally wrote a blog on this. Take the time to read and understand it as it's really not that technical.
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      Louis-DT-WR
                                      #218
                                      @nottsbiker I did consider the FMF but I saw a thread where someone put one on a Dt200r and it was close to the rad scoops and didn't want melt them, also the DEP were UK stock.
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        Louis-DT-WR
                                        #219
                                        Got the hang of it now. I will "repair" some of my broken images
                                        • Louis-DT-WRL
                                          Louis-DT-WRL
                                          Louis-DT-WR
                                          https://youtu.be/apMFEINtbQU
