  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 162.1k Views 5 Watching
  • Louis-DT-WRL Louis-DT-WR
    Still waiting for the very last bits 😣
    But made a quick video (slideshow) https://youtu.be/kJED24hS3x4
    @Louis-James amazing
    • Louis-DT-WRL
      Louis-DT-WRL
      Louis-DT-WR
      So today I did a test start to check all lights work.
      Speedo and all lights on the new clocks work.
      When I try the indicators....
      the rear indicator stays on solid and the front does not light up , the clocks light stays on solid also...
      This happens on both left and right hand side.
      I think this is exactly what happened when my dtr relay went... Any thoughts? Hard to source the correct relay.
      NINJAN CalumC 2 Replies Last reply
        #103
        @Louis-James Does the clock light disappear when you put it in gear?
        I presume that you've checked all the wires, grounds, connectors, fuses etc. to ensure that there's nothing shorting out? No LED's all lights are regular bulbs???
          @Louis-James Double check the wiring to make sure you haven't connected up the wrong sides. Sounds like a relay issue to me, I've had that a few times before.
          • Louis-DT-WRL
            Louis-DT-WRL
            Louis-DT-WR
            All the looming was Mint and I cleaned all connections. The neutral light goes off when in gear... I'm pretty sure it's the regulator issue I had on my dtr
              Louis-DT-WRL
              Louis-DT-WRL
              Louis-DT-WR
              @Calum that's what I think but it's a hard part to find. All earths were cleaned
                I think I've had this before when only one of the indicators are connected.
                • F
                  F
                  What wattage lamps have you used in the indicators?
                  When I changed mine to higher wattage i got the same symptoms you're describing.
                  • F finnerz89
                    Louis-DT-WRL
                    Louis-DT-WRL
                    Louis-DT-WR
                    @finnerz89 they're original ones but new
                      @Louis-James Check that the bulbs haven't gone and/or that the loom provides continutity throughout.
                        Louis-DT-WRL
                        Louis-DT-WRL
                        Louis-DT-WR
                        @Calum cheers call, seems a bit of a coincidence that it's both sides
                          @Louis-James Just make sure front right is connected to rear right and front left is connected to rear left.
                          • F
                            F
                            If the lamps are standard my money is on the relay. Try disconnecting one and see if you get a flash then.
                            Is the switchgear new?
                            • F finnerz89
                              Louis-DT-WRL
                              Louis-DT-WRL
                              Louis-DT-WR
                              @finnerz89 does a single flash then stats on.. always the small things take the time haha.
                              F 1 Reply Last reply
                                F
                                F
                                @Louis-James another thought, is the light in the clocks led? Try disconnecting that if it is
                                -1
                                  Yeah, could be your chinese clocks causing problems.
                                  • F finnerz89
                                    Louis-DT-WRL
                                    Louis-DT-WRL
                                    Louis-DT-WR
                                    @finnerz89 no because I'm only using the new clocks shell. All wires and bulbs I swapped over
                                      F
                                      F
                                      @Louis-James hmmmm 🤔
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        Louis-DT-WR
                                        https://youtu.be/La0VeAoF2fU
                                        • F
                                          F
                                          Looking good 👍
