  4. TDR issue
TDR issue
97 Posts 12 Posters 33.7k Views 1 Watching
  • O
    O
    • 1 vote for red 😁
    • NottsbikerN Nottsbiker
      @tdrnoob said in TDR issue:
      @calum So you just removed all 2 stroke oil from the tank and started to use premix?
      Not quite but it is easy to blank off the injection system properly and you can even buy plates to cover the missing oil pump. If i remember correctly you also need to up jet by something like 5% to allow for the oil being in the fuel.
      T
      T
      TDRnoob
      @nottsbiker I was trying to search for these plates. Where did you see it? Could you please send me the link how it looks like.
      • NottsbikerN
        NottsbikerN
        What plates are you on about? Do you mean the Jack up plates then I think it's either DTR shock or links (dog bones) to raise the rear end
        T 1 Reply Last reply
          T
          T
          TDRnoob
          @nottsbiker to cover the missing oil pump
          • NottsbikerN
            NottsbikerN
            Ah sorry i misunderstood
            They come fitted to the WR200 as standard or you can buy them on ebay with this item number
            192262337902
              192262337902
              T
              T
              TDRnoob
              @nottsbiker Thanks
              • NottsbikerN
                NottsbikerN
                No problem dude
                  Mybelgarda oil pump failed and couldn't be adjusted. It just rinsed oil.
                  I went premix in the end.
                  T
                  T
                  TDRnoob
                  @calum Hi. Did you change jetting after when you went for premix? If changed then could you remember what sizes for pilot jet and main jet. Thank you
                  • T TDRnoob
                    @tdrnoob I ran a completely different carburetor, so all my jet sizes would have been changed.
                    Plus I ran far from standard settings. Jetting must done to suit the machine you are riding, no two machines are the same so jetting is best done to accommodate this.
                      T
                      T
                      TDRnoob
                      @calum I have found the details of my carb it is
                      PHBH28 Dellorto carb
                      main: 142
                      choke: 60
                      atomiser: 266d
                      needle: x18
                      pilot :45
                      I have removed the oil pump and installed the plate cover for hole. Tomorrow engine is coming back after bottom rebuild. Just thinking should I change jetting. Any advice
                      • T TDRnoob
                        main: 142
                        choke: 60
                        atomiser: 266d
                        needle: x18
                        pilot :45
                        @tdrnoob I'm not familiar with that carburetor myself, as said, jet accordingly.
                        If it's detonating, if it's spluttering, then you may need to jet to suit.
                        But at a guess I wouldn't have thought you'd need to rejet.
                          T
                          T
                          TDRnoob
                          @calum Thank you
                          • NottsbikerN
                            NottsbikerN
                            You should be able to get any spares you need from Allens Performance who stock parts for all makes of carb
                              T
                              T
                              TDRnoob
                              @nottsbiker Hi. You wrote earlier to increase the jetting by 5%. It has pilot jet and main jet so do you mean those two to change to higher ones by 5%?
                              I will test the bike with the original ones first
                              • NottsbikerN
                                NottsbikerN
                                Ps I've picked up a complete pdf of the 3SH parts list with full pictures and Yamaha part numbers from the German TDR forum.
                                I'm currently in France on holiday but can email it to you when I'm near some wifi if it's any use to you?
                                • T TDRnoob
                                  NottsbikerN
                                  NottsbikerN
                                  I'm not an expert on jetting just relaying what I'd read years back. If in doubt get it set up by a tuner
                                    T
                                    T
                                    TDRnoob
                                    @nottsbiker Thats great! I really need it.
                                    Could you please email it to me d.matuiza@gmail.com
                                    Many thanks
                                    • NottsbikerN
                                      NottsbikerN
                                      Sent over!
                                      • MightymanM
                                        MightymanM
                                        @Nottsbiker is there many pages? It would be great if we can get them uploaded into a thread of their own.
                                        • NottsbikerN
                                          NottsbikerN
                                          Iirc about 70 ish
