  4. Yamaha DT125R '01 - Running Project
portingignitech4dldtrwr200
135 Posts 27 Posters 138.6k Views 6 Watching
  • A Offline
    A Offline
    andrewj1680
    0_1494210331154_Screenshot_2017-05-08-03-13-33-1.png 0_1494210363397_Screenshot_2017-05-08-03-13-45-1.png
    I did the whole polishing thing when I first started building my cr but by the time I finished I had decided I didn't wanna polish after every ride so I powder coated it black instead, did look the part tho
    DartyD N 2 Replies Last reply
    • A andrewj1680
      DartyD Offline
      DartyD Offline
      wrote on last edited by Darty
      #82
      @andrewj1680 Bang on! That would of looked mint, it's a shame alloy has to oxidise so quickly,
      • A andrewj1680
        @andrewj1680 Oh man, that sure looks damn sweet, and such a shame to do all that work and then get all that lovely shiny metal blacked out. But hey-hoo I get why and it was your choice.
        A 1 Reply Last reply
        • N NINJA
          A Offline
          A Offline
          andrewj1680
          @CYBER-NINJA I preferred the polished look but I'd of spent more time polishing it than riding it every time I took it out, Can you imagine trying to avoid every puddle you came across lol that wasn't for me if it's there I'm gonna ride it
          • DartyD Offline
            DartyD Offline
            (6mm Stainless Steel - Brass 13-14mm spacers)
            I made DXF files for Waterjet cutting - for a Stainless Calliper adapter and spacers for a SM conversion using the 'YZF125' Brembo calliper.
            If there are a few members here looking to do SM conversions, I could get a few kits together with bolts,
            Just a limited run as I have the time for the moment.
            • DartyD Offline
              DartyD Offline
              #86
              32 degrees, sticky rubber, cotswold country lanes, 2strokes and considerable beer intake on par with University life.
              I ride this thing 22 miles a day as a daily to go work, built this thing to be used and I just 'turn it up' a little on the Laptop for a blitz on the weekend somewhere.
              Drawing this project to a close, and enjoying the result, or atleast this iteration of it so far...
              I had some clearance issues with the Powervalve under expansion. I removed material in increments by machine sanding.
              Custom bracket for the FMF Powercore1 can. Fits on a DTR well.
              Built the headlight brackets,
              WR400 Face swap.
              There is no room left on this bike. Made a mount for the Ignitech Ignition, secure, doesn't suffer from heat exposure and most importantly it's accessible.
              As for cooling, air flow is fine still.
              Modified AS3 Silicone WR200 radiator hose's to suit this mongrel application.
              This leads me to something interesting I found,
              I needed a new WR200 coolant pipe, turns out later 4BF4 1995' WR200s use a larger 18mm bore coolant pipe.
              I got one brand new old stock from Japan. I've rust protected it, primer and a Gold top coat for a little bling.
              Then of course a 4BF4 Waterpump cover is required.
              4BF4' Pictured above vs 125R/200R
              I never knew Yamaha updated the cooling for the WR200, so I had help getting a used one.
              IT ONLY JUST FITS... Tight bruuuh. I made a brace for the coolant down pipe as it's just a braised joint and I managed to split my last one like a clot.
              Originally this mounts onto the WR200 Cylinder, so ideally this has to be done to the 125R barrel.
              Cooling is now more than adequate,
              WR200 Inlet, TM32 fitted. This inlet gives you more angle to use larger carburettor bodies.
              WR200 vs DT125R. Inlet tract a little longer, Mounting points have to be modified and crankcase stuffers removed.
              New YZ braided brake lines and removable exhaust joint to get the FMF onto the DEP.
              (An oldschool mechanical display setup. Dorky but I love this older stuff.
              The fun bits. Built to be ridden alot!
              Using a base map close to a TZR125 4DL SP, It runs particularly well under 6K.
              This DT now shifts.. I use a 4DL servo setting which utilises the PV opening later than the DT or TDR 3SH.
              It's far from perfect, but a safe base tune to run on as this is my daily as the weather is so good.
              It's run in properly now, and it is glorious. It sounds fantastic over 10,000rpm.
              Powerband is up at 9,500rpm and it pulls hard to 13,000.
              DTR Gear ratios are perfect for this TZR head and it's acceleration characteristic is spot on, 0-62 less than 6 seconds.
              More to come, more bits from Japan to arrive and then finally a Dyno session with a TM34ss fitted.
              Stay safe!
              declanD CalumC 3 Replies Last reply
              3
              • DartyD Darty
                WR400 Face swap.
                Stay safe!
                @Darty my power comes in at around 9 but only pulls for a bit is this normal just because you have a fancy set up?
                • DartyD Darty
                  WR400 Face swap.
                  Stay safe!
                  @Darty btw that bike is legendary well fucking done man
                  DartyD 1 Reply Last reply
                    DartyD Offline
                    DartyD Offline
                    @declan Cheers boss, yeah I guess it hasn't risen much, it's not running right at top end RPM's. Possibly the Reeds failing.
                    It's amazing how much more torquey it is than before, it's not a bad commuter bike still πŸ˜‚
                    • DartyD Darty
                      WR400 Face swap.
                      Stay safe!
                      @Darty Oh my, yes bud this is fantastic!!!!! πŸ˜„
                      • MightymanM Offline
                        MightymanM Offline
                        Very interested to see the dyno results!
                        • J Offline
                          J Offline
                          Jens Eskildsen
                          wrote on last edited by Jens Eskildsen
                          #92
                          Yeah me 2 πŸ˜ƒ
                          • C Offline
                            C Offline
                            conmador
                            hey, are the calipers you designed for the dtx front brake? or is it for dtr front brake? because if it is for dtx front brake i would be interested
                            • M Offline
                              M Offline
                              Minia
                              Thats a cool dtr!
                              • DartyD Darty
                                Stevie WonderS Offline
                                Stevie Wonder
                                @Darty this is what’s sat at the top of my tabs list for the past 4 weeks, your bike build. It’s Mk1 stage with the aprillia headlight and YZ wheels is probably my biggest inspiration for my bike to date. Timeless classic looking crosser and I can’t relp but keep looking at or referring to the pictures of it late at night πŸ˜‰ (when I’m on eBay that is and not a certain other website πŸ˜‚)
                                  DartyD Offline
                                  DartyD Offline
                                  @dtStevie98
                                  Lost but not forgotten, back on a standard Top end, bent Shifter fork and Clutch issues, bent caliper hanger, seized caliper piston, slightly bent yokes as it turns out from long ago, and the Dep Expansion pipe that is only 65% left in existence.
                                  I also dented the tank very badly and cannot pull it out, it's trashed,
                                  And the Power-valve which was 'fully sent'. It blew the remaining pin out the exhaust,, I think as the bottom end didn't grenade itself.
                                  It was doing 80mph in 5th gear and still pulling, so it was mission accomplished.
                                  Full Yeet.
                                  • DartyD Offline
                                    DartyD Offline
                                    #97
                                    *Nobody
                                    ME:
                                    *A custom inlet tract for a DT125R.
                                    Couple beers and some eyeballing and you can make whatever you want.
                                    Getting to old for Pod filters and hacking shit bits together. So if you could, why not re-design OEM equipment in your favour?
                                    Knocked these up on Solidworks to be a straight swap into the frame and Airbox.
                                    The brief, for my application, getting an inlet tract as straight as possible for 34mm or larger Carburettor to fit around my YZ490 shock, which is way larger than the original DTR unit.
                                    Science bitch.
                                    I have access to a 3D printer, so I've been designing and making prototypes just for a bit of fun after work,
                                    Technology these days....,
                                    Walney-ReptilesW 1 Reply Last reply
                                    4
                                      Lions smart, is it up to the task though...
                                      • DartyD Darty
                                        *Nobody
                                        ME:
                                        Science bitch.
                                        Walney-ReptilesW Offline
                                        Walney-Reptiles
                                        @Darty Would you be kind enough to send me the STL file for the intake manifold so i can 3d print this on my printer please buddy?
                                        • Walney-ReptilesW Walney-Reptiles
                                          DartyD Offline
                                          DartyD Offline
                                          @Walney-Reptiles Yeh when I've made a working prototype I'll let you know bud,
