TDR issue
Another update with the brand new issue
Cold bike. I couldn't start start it. It didn't accept the throttle. Started with the choke only. When warmed up everything worked fine with the choke off.
Spent about 10 minutes on adjusting the carburetor air screw (to get the highest rev on idle)
Noticed that the bike is heating up a bit to fast. (Heat arrow pointed at 3/4)
Decided to go for a ride
In the beginning accelerated well, after 2-3 minutes started to feel like something is dragging behind.
Engine was running very slowly and it didn't accept the throttle.
I stopped and noticed that in neutral gear is hard to push bike forward of backwards. Looks like the engine is tight?
When it gets colder then gets back to normal.
Video
https://www.youtube.com/watch?v=KV5ynUc5-xw&feature=youtu.be
Any thoughts?
Regards
Video
Any thoughts?
Regards
@tdrnoob DEAR GOD
Poor engine.IT'S LEAN FOR SURE,
I'm pretty sure that is an outrageously lean fuel condition.
That is bad.
Very bad.
Get to Jetting that before riding it anymore,
Did you check the carb was still on factory settings and ensure that it was squeaky clean?
@nottsbiker I didnt change anything in carb. Dissembled and cleaned with the carb cleaner. Then put it back together as it was before
Worth checking that the inlet rubber is not perished then (between carb and engine). Mine is shot to pieces and I've yet to see a new one for sale
Belgarda version?
Watching loads of items I need at moment but would definitely buy one later at that price
@nottsbiker I will check that.
Thank you
Thank you
Any progress regarding the weird noise coming from the engine?
Be interested to hear how you are getting on as well
@irongamer727 Do you mean the whistle?
Looks like it is the problem with the starter, but I think it does not affect the main issue
Spark plug news
According manual it looks like it is carbon fouling colour
Causes
rich fuel/air mixture (maybe air leek)
faulty choke (Not sure how to check as it looks all right)
blocked air filter (probably not)Pictures
Lebancoin
You will struggle to find anyone willing to post to the uk and the shipping rates are crazy from here.
Loads of lovely WR200's out here too
J'ai trouvé une annonce qui devrait vous intéresser sur leboncoin
@nottsbiker said in TDR issue:
Lebancoin
Oh please bring me some wr200 forks back
Loads of 200's in France but most seem to be down south over near to Belgium / Switzerland and I'm currently in the West.
WR200's go for anywhere between €1000 and approx €2000.
Unfortunately France isn't up to speed with couriers etc and you pay silly money to ship from here to the uk whereas the other way round it's much cheaper.
DTR's go for €500 upwards so it's easy to see how Unit 5 Motos (etc) can sell them for £1500 unregistered in the uk by bringing in about 10 every visit.
If i was in the market for a tidy WR200 I'd drive over here via the tunnel and buy one in France as the choice is so much better than at home.
http://www.leboncoin.fr/vi/1178634948.htm
@tdrnoob first thing I did was removed starter motor to see if its really that problem and it was. I had a broked bearing stay. Thats a plate behind a flywheel where starter clutch sits on needle bearing . I am replaced it , cleaned and lubed everything in there and its ok now.
Number 1 was broken .
